Originally Posted by cre
The turbo oil pump is a higher flow with different internal gearing. Aisin (non-Toyota branded) are generally a good deal less expensive you'll find at the dealer whether online or local.
Sorry Cre, you seem to be the go to guy. Without you this forum would really struggle, thanks for your continued efforts!
I need a bit of clarification on this. So the turbo oil pump has higher flow and works fine with the 7MGE - correct?
So were you saying Aisin makes the turbo pump, or were providing a second option ie you could get the aisin version of the oil pump either turbo or NA, from a dealer or online - and it would be cheaper that the toyota version?
