Thread: Hard to start
Old 01-03-2012, 04:08 PM   #1
lmmr74
lmmr74 is on a distinguished road
Default Hard to start
So i did had a BHG. It was fixed, the engine head was machined, news bolts, new gasket etc...I told the mechanic to torque the bolts at 75 lb instead of the 58 mentioned by Toyota. After a road test the car woks fine, no overheating, no loss of water. However i still have the heat soak synptoms that i was experiencing before fixing the BHG, everytime i drive the car and shutt it off, after 30 min if i try to start it again, it's hard to get it started. I had this problem before i fix the BHG...Is this heat Soak? Can this be a problem with the fuel injection system/fuel pump?
Any help will be appreciated!
Regards
lmmr74 is offline   Reply With Quote
