This is not a higher revving engine, expecting it to produce power beyond the last 10% before redline generally only results in disappointment. If you're running a stock setup you're doing nothing but wasting time and money... if something's broken and making the normal drop off worse well that's another story and you should fix it before doing anything else. Is the entire system already restored and healthy?
