Originally Posted by cre
Have you checked for diagnostic error codes? Look in the FAQ section for a how-to if you need. Start with that.
I don't understand what you mean by "reign on the heat"... you just referring to running the engine hard or is your climate control or engine temp part of the issue?
I meant to say turn on the heat. And there are no trouble codes
