Thread: Steering Noises
Old 10-11-2005, 01:24 PM   #5
SupraMan1784
SP58GT
i was thinking the steering rack also...i had that problem...but check the belt and pulleys first..since mine were ok...i found that one of my joints was ripped...so i bought an aluminum one for about $225...its kind of a bitch to install though...but its do-able...would take you about 2.5 hrs if you know wut ur doing..a little longer but anyone can figure it out...must make sure you change the power steering fluid..and all the lines are tight...drain teh fluid...keep the cap open...start the car and turn the steering wheel all the way to one side then teh other...do it like 4 or 5 times... so the fluid gets back into the lines and you should be ok....i was an idiot...i dint check my lines i poured a bottle and it came out the bottom...and i was wondering why the steering still sucked...one of my lines wasnt tight...leaking like crazy
Now: Saving for an MKIV
Broken Rides:
