Old 01-20-2012, 12:05 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by priyesh12 View Post
Hey Guys,
I have been on so many forums and none of them have the courtesy to help out a supra owner in need! So I was recommended to this forum and lets see if he was right!
(Warning I am a partial noob but learn fast)
My Issue:
I bought a Gizzmo MS-2, its a full system, includes; boost controller, fuel cut defender and turbo timer.
I have done the connections for the boost controller and fuel cut but am stuck on the last part. The last requirement is to connect wire 'A' to a constant 12v supply and wire 'B' and wire 'C' to ignition one (one needs to be 'on' when the car is on the on position lol) and ignition two. I do not have a noob wiring diagram for my ecu because i would like to connect those wires directly to the ecu....could someone please point out which wires i can tap into to make this work!
I would really appreciate someones help,
Thanks
Glad to help, but let's start at the beginning. Are you working on a '93-'98 Toyota Supra? Turbo or non-turbo?
Life begins at 30psi.
