I did some research and found autoshop101.com to be very imformative. Neither is actually needed, but the clutch switch 0/12+ helps determine the proper idle speed based on other inputs and the brake switch modifes fuel cut rpm. Ill get these hooked up in a few weeks, but now I can tool around town knowing the ecu wont be thinking the wrong things.
