I don't know how your not finding performance parts, they are all over. I am doing my build through titanmotorsports mostly. Them, suprastore, jscspeed, horsepowerfreaks, enjukuracing has some parts, arizonaperformance has some stuff(mostly brakes and look good stuff, im getting the cam covers and centerpiece from them) and several others. Just google MKIII performance parts and all kinds of places show up.
For parts it depends on what you want to do. You'll need to rebuild the bottom end, i would get new pistons and rings as well if the rebuild kit you decide on doesn't come with them. You can either upgrade your CT-26 or get a different turbo and header. All turbo headers I have found are set up for an external wastegate. Either a piggyback system or a standalone, new fuel pump, FPR and injectors. You can decide on if you want a FFIM or keep your stock one,have to do custom IC piping if you do a FFIM. You can get the head ported and polished, bigger cams, bigger valves, better valve springs and seats. Oh and if your going to push that much power would definately look into a MHG.
There are all kinds of things you can do with the 7MGTE, just because it isn't a 2JZ or a 1JZ and is supposedly a horrible motor for BHG doesn't mean it can't be made reliable and to make power. Its out there and just requires a little searching.
Where are you from in OH, im from there originally, moved to WA because the army said so, lol.
