Originally Posted by cre
If it's an uncoated, paper gasket I always use a good gasket dressing... This isn't the same as trying to pack in 5 tablespoons of RTV form-in-place-gasket silicone. Whatever you use just a very thin coat is all you need... I prefer spray dressings for uniformity and to prevent buildup. Make sure it's coolant compatible... they're rare but some dressings are not compatible with some of the ingredients used in coolant.
Could you recommend anything specific? What's the stuff you use?
