Thread: Custome Air Box
Old 01-25-2012, 03:54 PM   #1
pandrade
pandrade is on a distinguished road
Default Custome Air Box
Im in the procces of bouilding a box for my intake on my 7mgte. I am buying the K&N kit, now whith this installed im going to take the right fog light out and make a velocity stack into the fog light which will run plastic pipeing into the stock air boxes location throught that little oval cut in the metal behind the headlingt, my thoughts are to match the right size piping into the box. im probably gona be using aluminum for the intakes pipe its self and wraping it whith dei exhaust wrap to keep the aluminum from heat soaking.
My main question is what material should i make the box, and the piping whith? i was thinking fiber glass for the box because it doesent absorbe heat like metals do, and aluminum for the intake pipe ( the black accoridan) wraped in dei wrap.
Im open to any better suggestions
pandrade is offline   Reply With Quote
