Old 01-26-2012, 06:15 PM   #34
Nathaninwa
Nathaninwa is on a distinguished road
Arrow
Thanks for the reply Cre. With the one tooth adjustment on the wheel and a slight turn in on the idle bypass, everything is still in check. Truck runs great (except for a bad cold start injector) and I'm pleased with the responce and power, read that as low end tq, that this motor has now. I'm still unsure if I have an NA or turbo intake cam, so in a while ill pull the cover and measure lobes.
But for a truck that's 4500lbs, geared 4.88 with 36 inch bias ply tires and duel transfer cases, it go really good.
Thanks for all the help.
Nathaninwa is offline   Reply With Quote
