cleaning wise i couldent do much because like you said i found out it was sealed so i made shure there wasent any debirs or corrosion on the spring,
i dont belive is a vacume leak because i checked all the hoses to see if there properly conected and in good shape, i think im gona end up having to buy a new one, its 75$ but if its a wear item i guss its just its time. now whith this replaced i should stop geting code 51 and idle correctly right?
