Old 10-11-2005, 07:00 PM   #1
Littlestan
Littlestan's Avatar
Default The solution...
Drcusupra,
This is a Do-Luck (RXB) Center Support Bar. I would imagine it would take
most if not all of your flex worries away. Easy to install and fairly cheap.
This is what the manufacturer has to say;
Drastically stiffens up the weakest point in the unibody frame which helps to
eliminate body flex under extreme loading. Increases torsional as well as
overall structural rigidity. Note that the combination of a front, center and
rear bar works to create an approximate 100% increase in structural rigidity.
Only a rollcage helps further. Especially good for targa-equipped cars.
Cheers!,
-=Littlestan=-
ID:	32   Click image for larger version
