Originally Posted by warmkop
they are diesel turbos but i dit some research and the people who used it got good results same as the garret turbos just tipe in holset hx 45 there is alot of stuff on them.
Sounds like an experiment to me. Unless the turbo has been spec'd to produce optimal horsepower gains in a 3.0L gasoline engine, I can't recommend it. However, if you do decide to go forward with this experiment, I'd ask a bit favor of you to please post your results here.
