Old 02-12-2012, 04:20 AM   #10
Fix the code 51 if it's genuine. You cannot set the ignition timing with any error codes present. The code 51 won't stay stored. If you press the throttle while in diagnostic mode you'll get a code 51 but if you take your foot back off the throttle and the A/C signal is correct (off) then the code will go away again after 30 seconds or a minute.
No sweat.
