So you've just checked for codes? Because code 14 has absolutely nothing to do with the fuel system and it isn't going to go away by itself. As I'm sure you've already read it indicates a bad igniter, coils or ECU. Intermittent operation is quite common when these go out but typically you'd also be seeing problems while the engine is running.
Did you change the fuel filter when you changed the pump?
The 7M-GTE doesn't use a distributor... but you do have a CPS and multiple ignition coils which may fail.
Does engine temperature affect this problem?
I would start with checking cables, battery voltage (unlikely culprit but worth checking), ground point (especially for the igniter and coil pack), test the igniter and coils as shown in the TSRM.
