Originally Posted by Green7mgte
I thought they were high impedance. I was at work tho posting from my iphone.
You thought correctly... they are. You can use high impedance injectors on an engine which came with low by removing the resistor pack but you cannot run high impedance injectors with an ECU that's built for low (at least not without a good amount of work... often including a different ECU
can you make that a sticky please. or move to the faq.
I'll move it to the FAQ for now. I may put together a more concise thread without all the additional chatter in its place later on. I didn't realize that this upgrade wasn't even covered in the FAQ.
