It's in diagnostic mode as long as the jumper is in place and the ECU is powered. The engine need not be running although running it and driving it will sometimes reveal additional diagnostic faults; nonetheless, for your tupical diagnostics just leaving the engine off with the key turned to the "ON" position is sufficient. Put in the jumper while the ignition is "OFF" though.
