Old 02-25-2012, 11:23 PM   #11
priyesh12
priyesh12 is on a distinguished road
Cool. Also, toluene (also known as xylene) is a good octane booster - please do some reading before using it though, I believe you have to mix in some marvel mystery oil or 2-stroke synthetic motorcycle oil along with it.
Anytime. I assume you also checked above the cut point, and confirmed that the voltage is actually getting clamped. If so, I agree it looks very good for this device.
Okay will check that out....and the voltage is getting clamped beyond the cut off point, in this case 4.3 volts if I have it set correctly.
priyesh12 is offline   Reply With Quote
