I take that back. The bolted together wires should bolt to the 100A Fusible Link (the Yellow wire)! Replace the yellow wire with a new FL (either another wire one or a sealed unit) and bolt the wires back where they belong. I didn't realize that nothing was running to the 100A FL but I did notice the wire colors were wrong for the ABS circuit... that'd be Blue and Black I believe. I assume you don't have ABS then.
