If it's for the stock alarm then the wires before the harness connector will be violet with red stripe and the other white with a black stripe. If not then it's not a stock component. I can tell you that the location where it's route through is not a location for any stock wiring. I suspect that it's either a hood sensor for an aftermarket alarm/remote start system or a DIY fix for the stock alarm.
If your stock alarm doesn't arm when the car is locked (the stock system didn't have a wireless remote, it is armed and disarmed by locking/unlocking the car door with the key) then you may want to try taping the switch in a closed position and try to arm the stock alarm. The "Security" light on the dash will light up once armed.
