As the title says, I'm going to dedicate a little time to cleaning out the MKIII FAQ. I'll be stripping posts from FAQ threads which don't explicitly provide info directly related to the thread; Adding new FAQ if I think a certain topic is addressed too often in the general MKIII board; and consolidating related threads as long as they don't make for a single thread which is too much to navigate comfortably (ie. no threads will cover:Head removal, block and head prep, MHG installation, head installation and torque specs for all the head hardware).
Please feel free to look through the FAQ section and if you think there is a topic which isn't covered, you find information which is duplicated or you find threads which may be candidates for consolidating into one thread, then post it here WITH LINKS.
If you want to submit a new article yourself, go ahead and start a new thread, add FAQ to the front of the title and put a link here so I'll know that I need to review it, possibly edit and move it to the FAQ *if I or another mod/admin agrees that it belongs there*. I'm not trying to be a control freak. I'm trying to reduce the size of the FAQ section so that new (and old) members have an easier time finding the info they need and are more likely to actually look for the information there first. Also, FAQ does stand for FREQUENTLY ASKED QUESTIONS. TIP: If you want to post a thread stating what the bird cage light is then post the details about all of the warning lamps and other dash indicators. Please do not link to information to another site. If you think that there is data there which belongs in the FAQ then quote it using the QUOTE /QUOTE tags and then give proper credit and supply a link to the original.
Let's make the most of this forum!
Thank you!
