The
coolant level sensor is in the coolant reservoir. It is located on the bottom and uses a float inside to determine the coolant level. You may get a false reading if this float is sticking on built up crud (from you BHG
). Sorry, I have no pictures at this time.
Another of the thermostat housing. This one shows the Cold Start Time Switch.
