Old 03-12-2012, 02:32 AM   #1
Wileyk24
Wileyk24 is on a distinguished road
Default Compression Test Results
Hey guys, I just picked up an 87 turbo in December. Had some really nice weather lately so I decided to give her a tune up. I replaced the air filter, spark plugs, spark plug wires, and since I had to pull off so much crap to get to the damn plugs I went ahead and did the valve cover gaskets as well.
While I was in there I figured I would do a compression test too. Here is what I found.
no. 1 cylinder - 180 psi
no. 2 cylinder - 185 psi
no. 3 cylinder - 165 psi
no. 4 cylinder - 165 psi
no. 5 cylinder - 170 psi
no. 6 cylinder - 185 psi
I like how high the readings came back. I performed the test on a cold engine and cranked 7 times for each cylinder. However, I am not sure if I should be concerned with the large difference on cylinders 3 and 4 vs the rest. The guy I bought it from has records that I haven't picked up yet, but he said the HG was done already. Its a super clean car with 91000 miles.
What do you guys think? Thanks in advance.
Wileyk24 is offline   Reply With Quote
