Thread: Bubbling noises
Old 03-13-2012, 03:47 PM   #1
It's not uncommon for a compression test to show a tiny leak in the HG. If the system doesn't burp the gas out normally after a couple full heat and cool down cycles you may want to burp it manually and see if the gurgle returns. If it does, inspect for leaks, test the pH of the coolant (to test for the presence of caustic combustion gasses), pressure test the radiator cap.
