Ok so I have a rebuild 7mge with forged rods and pistons and I would like to turbo it. But I don't want to remove the motor or drop the oil pan to add a drain. So I found a company called sts turbos and they make turbo kits that replace the muffle under the car and run all the oil lines all the way to the back of the car. So on the return line it has a oil pump push the oil all the way back up to the motor. So what I'm wondering is if I can run the stock ct26 set up and on the drain run it to the pump then to where the stock oil cooler goes.
Oil pumps
http://www.rbracing-rsr.com/oilsystems.htm
Sts turbos
http://www.ststurbo.com/
