mk3
yes i followed the tsrm manual. removed head bolts in order and put the fipg black sealant on cam covers also had the head machined, cleaned, and pressure tested. also i had the block prepped 4 hours to be perfect and checked with a percission straight edge. put new seals, new toyota head gasket, new turbo from turbonetics, oil lines valve cover gaskets and everything. i found out the leak it was from the dipstick from the oring seal becuase i got pissed and just took out the turbo and saw it was leaking from the o ring and leaking onto the oil pan making it look like it was leaking from the oil pan\. thanks guys i fixed my car and it purrs.
 2 fast 4 u
