Please try to post in the correct section. In most cases it should be obvious but if you are unsure each sub-forum has a description which you can read from the main directory. This obviously belongs in the MKIV section, not "non-generation specific" and definitely not in any of the FAQ sections. I'll move this to the MKIV section for you.
