Thread: Bubbling noises
Old 03-21-2012, 10:39 PM   #3
The smell could definitely be either. When the smell is at its strongest will be a significant indicator.
It could be a fuel leak at any of the junctions in the fuel supply or return; a leak in the injector seals on the fuel rail side (these little guys are very easy to pinch); a leak on the seals on the head side doesn't typically smell too strongly of fuel unless you're boosting.
A charcoal canister wouldn't really smell unless the BVSV wasn't opening and the check valve on the fresh air inlet was shot OR someone deleted it and didn't do it properly. The EVAP system is low pressure so you're not likely to notice the smell to any significant degree unless it's hot out or the engine is off and you've driven recently thus agitating the fuel in the tank.
You need to replace copper or aluminum washers every time they're removed. If you remove the injectors after the car's been run for 30K to 40K mi. or so you should replace the rubber O rings on the fuel rail side; This isn't a must, just safe.
