Originally Posted by DawgB0
No wonder never notice the gasket and block it wont affect the smog? I live in california so ya
Yeah, definitely can't delete any smog components living in CA. As stated earlier, check the gasket and bolts. If those all check out, inspect the valve and other parts for cracks. While you're there, make sure your vacuum lines are in good shape and routed properly; they likely wouldn't create the problem you're having, but a properly functioning egr system will help your fuel economy and help you on your next smog test.
In the future, please take a few more seconds when creating your posts to be more descriptive with your questions; the more info we receive, the better we will be able to help you.
