Strut bushings??? The only bushings in the struts are part of the damper. The rubber strut "hat" could always stand to be replaced on any car this old. Yes though... replacing the bushings generally refers to ALL of the suspension bushings and the subframe bushings. Inspecting motor mounts for damage is good form as well, especially if the vehicle is from '89 or newer as they use fluid dampened mounts versus the solid rubber mounts used in pre89 MKIII's.
