Thread: Should I Buy?
Old 03-31-2012, 01:29 AM   #3
Originally Posted by S-mk3-B View Post
Bads:
-Doesnt have papers for the swap
Paperwork for the engine? So you're taking their word for the 50K mi? Riiiiight. As for JDM engines.... I don't care if it's got only 5,000 miles... If it's possioble that it's been sitting on a pier for a year it's scrap in need of a rebuild. P E R I O D. I've seen plenty of "low mileage" engines which were complete garbage.
-Check engine light on (but said is due from the push start)
Bullshit. If this is the case they fucked up somewhere. The ECU doesn't check to see if you're cranking the starter with a key or a push button... Same goes for remote start systems. See the FAQ section for infor on checking diagnostic codes and pull the codes that are setting the CEL if you can get access to the car for a few minutes.
-Dash is off a little so the dash lights up low for some reason?
I have no idea what on earth you're talking about here, but it sounds like an excuse for a half assed job.
If this was originally a 7M-GE equipped vehicle make sure they installed an oil cooling circuit of some kind. The 7M-GTE came with an oil cooler (not the best setup but it helps).
