Old 04-02-2012, 11:31 AM   #21
interested!
Question stumped
Originally Posted by btwilson86 View Post
Ok, here are the pics I could get. Coil pack connector,individual coil connector, and the coil pack ground. I just realized that the first pic is probably useless since I don't have one of the wiring harness side, so hopefully someone else can post a pic of that one
Hi! -Had a close look at your ground wire , seems a bit loose, so could you be suffering bad starting? . Also, the ground from the plate should be connected to the cylinder head as the cam cover is mostly insulated ( sits on a rubber gasket and held down with rubber washered bolts ) .
May I suggest that a bulb and wire or a multi-meter be used to confirm continuity of the wire and the curcuit or plate is fully earthed .
