Originally Posted by Doat91
Thanks for the tips I'll be sure to check that out, my friend has worked on this car and assures me it is solid I only want to change the head gasket to prevent it from blowing on me while driving somewhere. I plan on just getting the car to look clean and under 400hp so nothing crazy just simple mods that won't affect reliability too much but it seems that to reach about 400hp I'd need to get bigger injectors and an AFM since I would have to turn up the boost. I'd only turn up the boost for when I need it though otherwise it will be at stock level boost for just normal driving. I'll make a build thread and ask more technical questions in there about suspension and try to do the work myself but if I can't do it I know a guy who owns a shop that works on race motors and cars.
I wouldnt do the head if it doesnt need it... Maintenance is better. Do a leak test (better than a simple compression test). Just because 7M's can blow headgaskets doesnt mean they will.. Proper torque, proper build = fine engine. Why fix something that isnt broken? : )
