Originally Posted by cre
Sure you can test it. Just find a shop which has the RARE Toyota TCCS test computer.... A suitcase with a dozen adapters and simulates a running vehicle. The TCCS ECUs are VERY robust. Aside from leaking capacitors or moisture damage they rarely fail.
And... WOW, that car is a nightmare (see: perfectly normal MKIII  ).
As common as the N/A MKIII is, I'd look for someone who's got one in your area and give 'em $20 to let you try theirs in your car for an hour. They're very commong.... I think I've got a couple buried in storage somewhere (probably being use to keep one of my chests of deisel tools off the ground :P ).
wow man... above and beyond. i am asking a friend for an ecu from one of his part cars and my question now is the year range and is auto and manual a different ecu?
also i found this!!!!!!
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=31
and i can use the diag box. but first im going to pull out the connectors and inpect for the usual ( bent terms, that good green stuff, etc)
and for those ppl who are looking at this thread i know one of yall had to have encountered a problem simular to this so.... HELP!!!
