Originally Posted by Blindedlegacy
btw, you never get answer my question about the ecu, which one can i put in my car?
Originally Posted by cre
The ECUs are a little different, but for your purposes it should work without modification... I can't recall but I'm pretty sure that at the worst you'll get an error code stored in the ECU for the ECT.
Unless I'm completely wrong, the alternator is not controlled by the ecu. It has an internal voltage regulator in the alternator. Also, the voltage you reported at idle is too low, it should still be 13.5 volts. As engine speed changes the available current will change as well, however the voltage should remain constant if the wiring and alternator are both working properly.
