Old 04-05-2012, 02:41 AM   #2
Joefishizzle
Joefishizzle is on a distinguished road
I would double check all your lines. Also make sure you have the low pressure and high pressure lines connected in the right spot. And could be your pump is bad if your hearing a whinning. Did you run the pump without fluid for a little?
Joefishizzle is offline   Reply With Quote
