Thread: F@#cking SMOG
Old 04-06-2012, 08:30 PM   #26
If there's no code stored it's possible it was excessive ping so make sure you're reading the ignition advance properly and make sure the mechanical timing is properly zeroed out.
I covered why you may get an O2 sensor code with a new sensor already, two possibilities.
If the TPS is bad enough to throw a code it'll be a code 41. Code 51 would only cause idle issues.
