Old 04-11-2012, 03:39 PM   #1
pandrade
pandrade is on a distinguished road
Default installing 4 channel mk4 abs into a mk3
hey every one i usualy post in the mk3 section becuase thats what i have but i started a thead about the stock 3 channel abs. cre recomended i post here and more or less ask phil. i was woundering if you could put a 4 channel into the mk3 if the mk4 came whith one. heres where the discusion started
http://www.toyota-supra.info/forums/...ing-valve.html
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
