in the future i would upgreade the pipeing to a bigger diamiter in the future. since my goal is 550rwhp ill need about 600 to reach my goal. in the futer ill go 2.75 inch pipeing whith a bigger more modern turbo from garret but at the moment ill stick whith factory diamiter but i will optimize the factory setup. since at about 200hp per liter you start to lose responsivness i can worry about bigger diamiter later down the road when i have more cash to put into it
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
