Thread: HKS AFR type?
Old 04-13-2012, 05:07 AM   #1
serv92
serv92 is on a distinguished road
Default HKS AFR type?
I couldn't find anything on this in the FAQs so im posting it here.
I got rid of my EGR valve because part of where it gets bolted on to the head got cracked apart, and it was to expensive to replace.
I want to go with the HKS AFR to fix the air to fuel ratio.
I'm sure I should buy type L because that is the one that changes the voltage coming from the AFM.
and the other type D changes the voltages from the map sensor to the ECU.
I want the one connects to the AFM right?
1987 7MGTE
serv92 is offline   Reply With Quote
