Old 04-14-2012, 07:17 PM   #10
Crop
Crop's Avatar
when i start the car cold it starts idle at around 900-1000 rpm...within about 3 seconds of this idle the check engine light goes on, at that exact moment idle drops to around 500 rpm and starts to fluctuates from 500-600rpms.. if i give it throttle to around 1000 the check engine light goes off, as soon as i let off throttle from that time the rpms drop to a stumbling 450-300 rpms with check engine light back on then returns to the 500-600 rpm range.
i started looking at the TPS connection and removed the wire harness for inspection.. i forgot to reconnect and started the engine..to my amazment there was NO difference in the cars idle or rpm from previous description above.. whatcha think???
i think i might be getting somewhere.. help me plz
