Am against all things that come in a bottle for a "quick fix". I was taught they do not work. While it may "work" for a bit, you are setting yourself up for failure. Then most of the people in this forum push their cars past their designed limits.
If one of them says to add some brake fluid to the transmission. Go ahead and hit them, it is a sure fire way to destroy it. Quality is doing thing right, shoody is doing things wrong because it is "cheaper". Actually in the long run doing it right is cheaper.
