this is the link on the FAQ'S that tells about shimmying the waste gate
http://www.toyota-supra.info/forums/...-websites.html
then click on this one www.SUPRAS.com - Member's Section
i wouldent take it off the FAQ's alot of other good thinks on that link i would warn about the bad effects of shimmying the waste gate , or maby make a FAQ page of most common mk3 and 7mgte myth's which would cover this
and on a side note does any one know of a good manual boost controller they would recomend
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
