The sarcasm flows like the advice and also the MKIII's woes.... Thick, free and without end.
There is no major difference between either engine which would cause such a mistake. Everything is in the same place, except for the PS reservoir which is mounted 10" left of the GTE's... The location of the clutch and brake reservoir are completely standard.
I'm not sure what book you're using but if it's that bad you may want to give it to someone you don't like. I recommend you buy a hardcopy of the TSRM (it's what we've been linking you to in this thread).
