Originally Posted by Josh122593
Im having issues getting my car to idle smooth.Can anyone make a basemap for 880cc injectors and 2.35ohms.Im having trouble getting battery offset correct.Ive tried multiple injector types in the setup wizard.Maybe i just need plugs?Heres a vid.
http://www.youtube.com/watch?v=95Cj7...1&feature=plcp
Consider trying a lower base fuel pressure. Agreed it couldn't hurt to try new plugs.
Also note that your idle really isn't too horrible, other than the fact it is a bit rich. What happens when you reduce the pulsewidth in the idle rpm range, at low-load (i.e. idle conditions)? With 880cc injectors, unfortunately, there's no way it'll idle like stock. Note that the oem 550cc injectors spray two streams of fuel, each directed exactly at each intake valve. The oem setup as thousands and thousands of hours of engineering time to make it run the way it does. It's nearly impossible to duplicate that without an equivalent amount of work by highly trained professional tuners.
