Originally Posted by realdeal
Ok so I found the correct pinout diagram, but the rpm signal isn't listed here. Anyone know which pin that is? I have the yellow connectors that are 10p, 18p, 24p.
http://www.fadingworld.com/CRE/Autom...gDiagrams.html
My diagrams hosted here are for the MAFT Pro, but if you look at the diagram under Step 1, Turbo, 1a you'll find it shows the locations you need for just about any air fuel controller: VTA, Ks and IGt.
I recommend you power the SAFC with a relay as documented in some of the other diagrams I've put up there.
