there should be somthing about this on the mk3 faq's
if an 87 i belive yes but you can buy motor mounts especialy made for the swap on pre 89 mk3's i know theres one swap on the faq's that has alot of info and pics
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
