oh your asking what should be the base oil to use whith the redline adative cre recomended right? i used lucas heavy duty which worked fine but like cre said my outside tire still chirps a bit but only in wet weather running on my junk tires. iv never tryed any other oil brands like mobel or valvoline or royal purple so i wouldent be able to recomend any
cre your thoughts maby base oil to addative ratios.
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
