Old 10-15-2005, 03:59 AM   #1
corewitz
corewitz is on a distinguished road
Default engines dropping when throttle depresses! help!
hey im having sort of a problem. I turn my car over and it starts nearly fine ( the engine jumps a couple times then starts) and it idles pretty normal at first. When the throttle depresses, the rpms die down to almost stalling the vehicle, and then jump back up and revs the engine. If I let it idle for a long time it slowly starts loosing idle speed.
Does anyone have a similar problem or an answer to what could be causing this?
thank you
corewitz is offline   Reply With Quote
